Installing Kodak EasyShare Z1015 IS Back Cover
  1. Installing Kodak EasyShare Z1015 IS Back Cover, Battery: step 1, image 1 of 2 Installing Kodak EasyShare Z1015 IS Back Cover, Battery: step 1, image 2 of 2
    • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  2. Installing Kodak EasyShare Z1015 IS Back Cover: step 2, image 1 of 1
    • Next, press down on the red lever which holds the battery in place.
  3. Installing Kodak EasyShare Z1015 IS Back Cover: step 3, image 1 of 2 Installing Kodak EasyShare Z1015 IS Back Cover: step 3, image 2 of 2
    • Once the battery has popped out of the compartment, simply pull it out of the camera.
  4. Installing Kodak EasyShare Z1015 IS Back Cover, Back Cover: step 4, image 1 of 3 Installing Kodak EasyShare Z1015 IS Back Cover, Back Cover: step 4, image 2 of 3 Installing Kodak EasyShare Z1015 IS Back Cover, Back Cover: step 4, image 3 of 3
    • Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides.
    • Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera.
    • Begin by removing the first screw located on the back of the camera.
  5. Installing Kodak EasyShare Z1015 IS Back Cover: step 5, image 1 of 2 Installing Kodak EasyShare Z1015 IS Back Cover: step 5, image 2 of 2
    • Next, remove the two screws located on the right side of the camera.
  6. Installing Kodak EasyShare Z1015 IS Back Cover: step 6, image 1 of 2 Installing Kodak EasyShare Z1015 IS Back Cover: step 6, image 2 of 2
    • After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
  7. Installing Kodak EasyShare Z1015 IS Back Cover: step 7, image 1 of 2 Installing Kodak EasyShare Z1015 IS Back Cover: step 7, image 2 of 2
    • Lastly, remove the two screws located on the left side of the camera.
  8. Installing Kodak EasyShare Z1015 IS Back Cover: step 8, image 1 of 3 Installing Kodak EasyShare Z1015 IS Back Cover: step 8, image 2 of 3 Installing Kodak EasyShare Z1015 IS Back Cover: step 8, image 3 of 3
    • Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
    • Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
  9. Installing Kodak EasyShare Z1015 IS Back Cover: step 9, image 1 of 3 Installing Kodak EasyShare Z1015 IS Back Cover: step 9, image 2 of 3 Installing Kodak EasyShare Z1015 IS Back Cover: step 9, image 3 of 3
    • Apply pressure on the left and right side of the camera and pull the back cover away from the device.
    • Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
katie newman
30 Reputation
3 Guides authored
Cal Poly, Team 5-16, Maness Fall 2010 Member of Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Members
11 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,405
