Kodak EasyShare LS743 Removing LCD Replacement
  1. Kodak EasyShare LS743 Removing LCD Replacement, Battery: step 1, image 1 of 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Removing LCD Replacement: step 2, image 1 of 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 1 of 3 Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 2 of 3 Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 3 of 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Removing LCD Replacement: step 4, image 1 of 3 Kodak EasyShare LS743 Removing LCD Replacement: step 4, image 2 of 3 Kodak EasyShare LS743 Removing LCD Replacement: step 4, image 3 of 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Removing LCD Replacement: step 5, image 1 of 2 Kodak EasyShare LS743 Removing LCD Replacement: step 5, image 2 of 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: step 6, image 1 of 3 Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: step 6, image 2 of 3 Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: step 6, image 3 of 3
    • Flip up the LCD screen and locate the two clear orange tabs.
    • Remove the tabs from the camera to remove the LCD.
Justin Mancherje
33 Reputation
2 Guides authored
Cal Poly, Team 2-8, Johann Summer 2010 Member of Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,244
