Introduction
This will teach you how to remove the capacitor in your Kodak EasyShare LS743.
Slide the orange latch sideways to eject the battery.
Remove the battery from the battery slot.
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
Connect the two capacitor wires briefly with a pair of metal tweezers to discharge it. You may see a small spark.
Remove 8 screws.
2 screws are in the front. (2x4.31mm)
2 screws are in the bottom (2x3.30mm).
4 screws are in the back. (3x3.33mm, and 1x 4.34mm)
Pull the black latch outward slightly to release the flex cable.
Carefully disconnect the orange flex cable.
