Introduction
To split the case with a stuck extended lens can prove a bit more difficult. There is a bit more carefully prying involved as it would be with a normal lens. No tools other than may be the plastic opening tools are necessary. It will take a bit of patience, but it is not impossible to accomplish.
Remove the batteries and the memory card from the device.
Remove the two screws located at the bottom of the camera.
Remove the two screws on the side of the device, to left of the camera lens.
Remove the two screws on side of the device, to the right of the camera lens.
Pry the casing apart at the seems, starting at the battery compartment.
Remove the front casing from the mid-frame, first.
Continue to remove the back casing from the mid-frame.
Do not remove the LCD screen from the device once it becomes visible.
Flip the LCD screen out of the holder from the top to reveal ribbon cable.
This camera had some obvious water damage..
Remove the three screws from the LCD holder
Dislodge the LCD screen holder from the circuit board connector.
Disconnect the logic board from the frame on the right side of the device.
Remove the small ribbon cable, connecting the button board to the logic board, with small pair of tweezers or hemostat.
Remove the screw on the top right side of the device connecting the LCD screen holder to the midframe.
Move the black clip into the upward position to disconnect the cable.
You will now be able to remove the LCD screen and its holder from the device.
Flip the black clips of the connectors into the opposite direction. Remove the lens and CCD cable.
Remove the two screws securing the lens to the midframe.
These are missing screws for the CCD sensor, lost in a previous dismantling.
Remove the single screw securing the lens to the mid-frame. The lens will now be loose.
Push the lens out of the frame in an angular direction, and remove.
