Open Kobold VK150 case
  1. Open Kobold VK150 case, Remove screws from housing: step 1, image 1 of 2 Open Kobold VK150 case, Remove screws from housing: step 1, image 2 of 2
    • Use a TX10 screwdriver
    • Remove the housing screws on the rear of the device.
    • 6 long screws
    • 3 short screws
  2. Open Kobold VK150 case, Remove housing cover: step 2, image 1 of 1
    • Place the device with the white lid facing up.
    • Start to carefully lift the lid at the front of the suction nozzle. Slowly work your way up to the stem.
    • At the top of the stem, a small plastic part holds in the gray casing of the suction cup!
  3. Open Kobold VK150 case, Separate parts: step 3, image 1 of 1
    • Now you can lift the flap of the vacuum cleaner bag. This was only held by the white lid.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Lukas Fritz
362 Reputation
3 Guides authored
One Comment
Sehr gute Beschreibung !
Ich habe im Augenblick so einen “Problembürger”.
Der geht nicht .
Wenn der Motor überbrückt wird läuft der Staubsauger .
Könnte vielleicht der Schalter sein??
Das Kabel habe ich geprüft,ist i.O.
Vielleicht hast du einen Tip!
Vielen Dank im voraus.
Jo
Jo Pe - Reply
Past 24 Hours: 10
Past 7 Days: 55
Past 30 Days: 264
All Time: 8,272
