Introduction
Screen Replacement of the 2011 first made Kobo Touch N905B
Back cover is removed easily with a plastic pick or other instrument.
Best to start on the top and then pull it out so that the USB plug does not block the way (not the way shown in the picture)
Use a lot of isoprop. The glue strip is right in the middle .
If the screen is broken, remove all parts.
Here you can use force, as you will not damage anything any further as it already is.
Search for replacement parts with following requirements:
6 inch
ED060SCE or similar (the last letters can differ)
Kobo N905C N905A are also compatible.
2 Guide Comments
Hi
I've got a kobo touch acquired from a friend. When I did factory reset it wouldn't connect to WiFi
Then, it suddenly had a line of dots down the middle.
Now it won't turn on, or do anything.
What can I do?
Hi Jane,
Sorry for that.
When it happened after a factory reset, this sounds like a software issue.
Maybe try a hard reset like described here: https://help.kobo.com/hc/en-us/articles/...
Otherwise I did not have this problem yet and do not know anything about it.
Leander
