Introduction
Outline what you are going to teach someone how to do.
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Locate the selector switch.
Remove the two Phillips #2 screws holding the selector switch in place.
Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
Pull upward to remove the motor.
You missed the step about removing the gearbox cover, even though it is shown as removed in the pictures. The motor cannot be removed with the gearbox cover in place. For anyone doing this repair, remove the four phillips screws holding the cover on and lift upwards. It is full of grease so have some paper towels handy in case any spills. When replacing the cover (after re-installing the motor) you may need to spin the gears (do this by rotating the motor fan) so that the accessory drive gear meshes properly in order for the cover to fit back into place. Be sure to align the planetary shaft with the recess in the gearbox cover as well.
2 other people completed this guide.
4 Comments
anyone know where I can get the hall effect sensor receiver that is on the motor shaft? Somehow it's missing?
I accidentally pluged my 110v mixer to 220v. Now, what are the possible parts that i need to change? How can i check if the motor is busted?
Maybe start with unplugging it ?
Ryan F - Reply
