This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓Since the hand mixer is no longer functioning, I disassembled it at a Repair Café. It was used too intensively and overheated. According to the website, spare parts from KitchenAid are not available for small kitchen appliances. I inquired via email and requested a replacement motor. I am still awaiting a response.
The device is not particularly easy to open. The installed electronics are unnecessary for a hand mixer. The motor is not protected against overheating.
I find the cost of approximately 90 Euros to be too high.
Use a small screwdriver to carefully pry off the chrome-plated cover.
Use a Phillips screwdriver to remove the two marked (recessed) screws.
There are two holes (c and n) under the silver sticker, indicated by the blue arrows. You can feel them. Push through these holes to push the tabs (yellow) underneath out of the way.
The bottom plate can then be lifted off from front to back. It must still be uncoupled at the back.
If you do not want to damage the sticker, you can also start prying off the cover from the back.
The carbon brushes are installed here. They are pressed against the motor armature by the copper spring. If the carbon brushes are worn out, alternatives of the same size could be installed.
When measuring with the multimeter, I measured different resistance values at different positions of the motor. I think that 160 ohms should be the normal value in every position. Please comment with any improvements.
Due to overloading, the motor overheated and some windings burned out. Afterwards, the fuse on the PCB tripped.
I found the RS9812SH motor online: http://www.cz-sanjet.com/products/Micro-...
Follow the steps in reverse order to reassemble your device.
