KitchenAid KHM512ER Beater Rings Replacement
  1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: step 1, image 1 of 2 KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: step 1, image 2 of 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Beater Rings Replacement: step 2, image 1 of 2 KitchenAid KHM512ER Beater Rings Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
  3. KitchenAid KHM512ER Beater Rings Replacement: step 3, image 1 of 2 KitchenAid KHM512ER Beater Rings Replacement: step 3, image 2 of 2
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
  4. KitchenAid KHM512ER Beater Rings Replacement: step 4, image 1 of 2 KitchenAid KHM512ER Beater Rings Replacement: step 4, image 2 of 2
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  5. KitchenAid KHM512ER Beater Rings Replacement: step 5, image 1 of 2 KitchenAid KHM512ER Beater Rings Replacement: step 5, image 2 of 2
    • Lie the motor down flat on a table.
    • Using a pair of tweezers, remove the ring from the plastic knob.
4 other people completed this guide.
Brad Daniels
621 Reputation
3 Guides authored
USF Tampa, Team 2-3, Sullivan Spring 2016 Member of USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Members
4 Guides authored
3 Comments
Anyone know of a site that sells replacement beater gears?
joescherzo - Reply
Nice set by step process but where does one get the rings?
M Stevens - Reply
try Sears parts.com
Yvette Tower - Reply
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 53
All Time: 6,611
