Introduction
If your mixer won't spin or is noisy, follow our guide on how to replace the worm gear.
Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
Using the same flathead screwdriver, remove the two 28 mm locking screws.
Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
Using a butter knife or putty knife, remove the grease from the gears.
Place the grease in motor housing cover.
