Introduction
Adjusting the beater head is a simple process involving only some handling of a screwdriver.
Lift the mixer arm and locate the large screw where the base meets the arm.
Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
Once your beater head is at the appropriate height, you're good to go.
4 other people completed this guide.
2 Comments
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
Thank you! Problem solved!!!
mirdel - Reply
Bravo,ich wusste bisher nicht, wozu die Schraube gut ist!
Arbeitsgruppe Dialog - Reply
Der Trick mit der Münze ist gut, eine 5ct Münze sollte bei laufender Maschine nur leicht touchiert werden und ein paar Millimeter in der Schüssel weiter bewegt werden.
KaiVi - Reply
