Shop the Holiday Gift Guide
Kitchen Scale (CM-103/10672Z) Disassembly
Views: 4.2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
51
Past 30 Days:
166
All Time:
4,185
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide clearly describes how to disassemble a kitchen scale.
Tools
    1. Kitchen Scale (CM-103/10672Z) Disassembly, Kitchen Scale (CM-103/10672Z) Disassembly: step 1, image 1 of 2 Kitchen Scale (CM-103/10672Z) Disassembly, Kitchen Scale (CM-103/10672Z) Disassembly: step 1, image 2 of 2
      • Remove the battery cover and batteries.
      Ask FixBot
    2. Kitchen Scale (CM-103/10672Z) Disassembly: step 2, image 1 of 1
      • Peel off the information sticker.
      Ask FixBot
    3. Kitchen Scale (CM-103/10672Z) Disassembly: step 3, image 1 of 3 Kitchen Scale (CM-103/10672Z) Disassembly: step 3, image 2 of 3 Kitchen Scale (CM-103/10672Z) Disassembly: step 3, image 3 of 3
      • Unscrew the ten screws (countersunk cross head 1,5 mm; 8 mm).
      Ask FixBot
    4. Kitchen Scale (CM-103/10672Z) Disassembly: step 4, image 1 of 1
      • Remove the black back cover.
      Ask FixBot
    5. Kitchen Scale (CM-103/10672Z) Disassembly: step 5, image 1 of 2 Kitchen Scale (CM-103/10672Z) Disassembly: step 5, image 2 of 2
      • Remove the tape which holds the electrical wires in place.
      Ask FixBot
    6. Kitchen Scale (CM-103/10672Z) Disassembly: step 6, image 1 of 3 Kitchen Scale (CM-103/10672Z) Disassembly: step 6, image 2 of 3 Kitchen Scale (CM-103/10672Z) Disassembly: step 6, image 3 of 3
      • Push down the click fingers and slide out the feet.
      Ask FixBot
    7. Kitchen Scale (CM-103/10672Z) Disassembly: step 7, image 1 of 1
      • Remove the backlight from the screen.
      Ask FixBot
    8. Kitchen Scale (CM-103/10672Z) Disassembly: step 8, image 1 of 2 Kitchen Scale (CM-103/10672Z) Disassembly: step 8, image 2 of 2
      • Unscrew the 5 screws from the PCB and screen (round cross head 1,5 mm; 6 mm).
      Ask FixBot
    9. Kitchen Scale (CM-103/10672Z) Disassembly: step 9, image 1 of 2 Kitchen Scale (CM-103/10672Z) Disassembly: step 9, image 2 of 2
      • Lift out the PCB and screen.
      Ask FixBot
    10. Kitchen Scale (CM-103/10672Z) Disassembly: step 10, image 1 of 2 Kitchen Scale (CM-103/10672Z) Disassembly: step 10, image 2 of 2
      • Pry out the PCBs which include the touch sensors (2).
      Ask FixBot
    11. Kitchen Scale (CM-103/10672Z) Disassembly: step 11, image 1 of 2 Kitchen Scale (CM-103/10672Z) Disassembly: step 11, image 2 of 2
      • Lift out the complete electronic circuit and remove the screen and connector.
      Ask FixBot
    12. Kitchen Scale (CM-103/10672Z) Disassembly: step 12, image 1 of 3 Kitchen Scale (CM-103/10672Z) Disassembly: step 12, image 2 of 3 Kitchen Scale (CM-103/10672Z) Disassembly: step 12, image 3 of 3
      • Pry off the metal cover from the top of the kitchen scale.
      • Remove the glass screen cover.
      Ask FixBot
Author
with
Floris
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 51
Past 30 Days: 166
All Time: 4,185
