Kitchen Faucet Replacement
  1. Kitchen Faucet Replacement, Kitchen Faucet: step 1, image 1 of 3 Kitchen Faucet Replacement, Kitchen Faucet: step 1, image 2 of 3 Kitchen Faucet Replacement, Kitchen Faucet: step 1, image 3 of 3
    • Rotate the hot and cold water valve knobs under the sink clockwise to turn off the water.
    • Turn on the faucet to relieve the pressure and any remaining water for about one minute.
    Ask FixBot
  2. Kitchen Faucet Replacement: step 2, image 1 of 3 Kitchen Faucet Replacement: step 2, image 2 of 3 Kitchen Faucet Replacement: step 2, image 3 of 3
    • Place a bucket underneath the valves to catch dripping water.
    • Turn the hot and cold supply line nuts clockwise until the water supply lines come out.
    • For a pull-down faucet, disconnect the spray hose from both the spray head and the main body.
    Ask FixBot
  3. Kitchen Faucet Replacement: step 3, image 1 of 3 Kitchen Faucet Replacement: step 3, image 2 of 3 Kitchen Faucet Replacement: step 3, image 3 of 3
    • Loosen and remove the nuts underneath the sink by using an adjustable wrench.
    • Remove the mounting bracket.
    Ask FixBot
  4. Kitchen Faucet Replacement: step 4, image 1 of 2 Kitchen Faucet Replacement: step 4, image 2 of 2
    • Use your hands to pull the faucet out of the sink.
    • Clean away any grime or sealant with a cleaning spray and towel.
    Ask FixBot
  5. Kitchen Faucet Replacement: step 5, image 1 of 3 Kitchen Faucet Replacement: step 5, image 2 of 3 Kitchen Faucet Replacement: step 5, image 3 of 3
    • Place the trim ring on the faucet hole.
    • Feed the faucet into the faucet hole and position it.
    • Different faucets install differently, so be sure to read and follow the instructions for your faucet.
    Ask FixBot
  6. Kitchen Faucet Replacement: step 6, image 1 of 2 Kitchen Faucet Replacement: step 6, image 2 of 2
    • Underneath the sink, put the mounting bracket back in place, and turn the nuts to tighten them.
    Ask FixBot
  7. Kitchen Faucet Replacement: step 7, image 1 of 3 Kitchen Faucet Replacement: step 7, image 2 of 3 Kitchen Faucet Replacement: step 7, image 3 of 3
    • Hook the water supply lines up by turning the hot and cold supply line nuts counter clockwise.
    • For pull-down faucets, attach the weight kit on the spray hose and connect it to both the spray head and the pull-out hose.
    Ask FixBot
  8. Kitchen Faucet Replacement: step 8, image 1 of 3 Kitchen Faucet Replacement: step 8, image 2 of 3 Kitchen Faucet Replacement: step 8, image 3 of 3
    • Rotate the hot and cold water valve knobs counter clockwise to turn on the water under the sink.
    • Once it is all done, check if there are any leaks.
    Ask FixBot
Finish Line
2 other people completed this guide.
Bongsu Kim
184 Reputation
1 Guide authored
1 Guide Comment
Great guide on kitchen faucet replacement! I was able to follow the steps and successfully replace my old faucet with a new one. The pictures and detailed instructions made the process much easier. Thank you for sharing this useful information!
Scott Robillard - Reply Share
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 190
All Time: 1,886
