Kindle Voyage Back Panel Replacement
  1. Kindle Voyage Back Panel Replacement, Back Panel: step 1, image 1 of 2 Kindle Voyage Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Back Panel Replacement: step 2, image 1 of 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture.
  3. Kindle Voyage Back Panel Replacement: step 3, image 1 of 3 Kindle Voyage Back Panel Replacement: step 3, image 2 of 3 Kindle Voyage Back Panel Replacement: step 3, image 3 of 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Back Panel Replacement: step 4, image 1 of 2 Kindle Voyage Back Panel Replacement: step 4, image 2 of 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
Sean Yap
1,307 Reputation
6 Guides authored
Cal Poly, Team 19-12, Maness Winter 2015 Member of Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Members
10 Guides authored
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 2,701
