Kindle Voyage Ambient Light Sensor Replacement
  1. Kindle Voyage Ambient Light Sensor Replacement, Back Panel: step 1, image 1 of 2 Kindle Voyage Ambient Light Sensor Replacement, Back Panel: step 1, image 2 of 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Ambient Light Sensor Replacement: step 2, image 1 of 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Ambient Light Sensor Replacement: step 3, image 1 of 3 Kindle Voyage Ambient Light Sensor Replacement: step 3, image 2 of 3 Kindle Voyage Ambient Light Sensor Replacement: step 3, image 3 of 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Ambient Light Sensor Replacement: step 4, image 1 of 2 Kindle Voyage Ambient Light Sensor Replacement: step 4, image 2 of 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: step 5, image 1 of 2 Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: step 5, image 2 of 2
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Kindle Voyage Ambient Light Sensor Replacement: step 6, image 1 of 3 Kindle Voyage Ambient Light Sensor Replacement: step 6, image 2 of 3 Kindle Voyage Ambient Light Sensor Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
  7. Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: step 7, image 1 of 2 Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: step 7, image 2 of 2
    • Gently remove the connector to the motherboard using tweezers.
    • Continue to carefully pull the rest of the connector from the adhesive connecting it to the Voyage.
    • Detach sensor from the top using fingers
Sean Yap
1,307 Reputation
6 Guides authored
Cal Poly, Team 19-12, Maness Winter 2015 Member of Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,322
