Introduction
Disassembling a tablet often requires some gentle prying of the frame. Be sure to exercise care during these first few steps(disassembling), and do not lose your screws! The Paperwhite is a sturdy tablet that can be broken down into just a few components. This guide will show you in just five short steps how to replace a faulty battery.
Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
