Kindle Paperwhite 1st Generation Battery Replacement
  1. Kindle Paperwhite 1st Generation Battery Replacement, Case: step 1, image 1 of 2 Kindle Paperwhite 1st Generation Battery Replacement, Case: step 1, image 2 of 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Battery Replacement: step 2, image 1 of 3 Kindle Paperwhite 1st Generation Battery Replacement: step 2, image 2 of 3 Kindle Paperwhite 1st Generation Battery Replacement: step 2, image 3 of 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Battery Replacement: step 3, image 1 of 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
  4. Kindle Paperwhite 1st Generation Battery Replacement, Battery: step 4, image 1 of 2 Kindle Paperwhite 1st Generation Battery Replacement, Battery: step 4, image 2 of 2
    • Turn over the midframe to locate the battery.
    • Remove the three Phillips 3.0 mm screws securing the battery to the midframe.
  5. Kindle Paperwhite 1st Generation Battery Replacement: step 5, image 1 of 1
    • Gently lift the battery from the bottom, and slide it out of the midframe.
Isabelle Burgess
1,621 Reputation
2 Guides authored
Cal Poly, Team 3-33, Amido Winter 2013 Member of Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 Members
17 Guides authored
Past 24 Hours: 11
Past 7 Days: 103
Past 30 Days: 514
All Time: 138,113
