Introduction
Use this guide to help you replace a faulty power button board in your Amazon Kindle Fire.
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
Pull the battery out of the Kindle Fire.
Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
Use a plastic opening tool to release the touchscreen controller connector.
Gently remove the touchscreen controller by lifting it up and to the right.
Use a plastic opening tool to lift up and disconnect the display data cable.
Lift up on the antenna connector with a plastic opening tool to disconnect it.
De-route the antenna cable.
Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
Lever the top side of the motherboard up with a plastic opening tool until it comes free.
Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
Lift the power button board out of the Kindle Fire.
