Kindle Fire HD 2013 Battery Replacement
  1. Kindle Fire HD 2013 Battery Replacement, Battery: step 1, image 1 of 3 Kindle Fire HD 2013 Battery Replacement, Battery: step 1, image 2 of 3 Kindle Fire HD 2013 Battery Replacement, Battery: step 1, image 3 of 3
    • Open up the device by using a plastic opening tool in order to avoid damaging the device.
    • To do so, find the seam along the outer edge of the device and use the plastic tool to pry the back panel up. Doing so may take some force and patience.
  2. Kindle Fire HD 2013 Battery Replacement: step 2, image 1 of 2 Kindle Fire HD 2013 Battery Replacement: step 2, image 2 of 2
    • Locate the battery's power ribbon.
    • Use nylon spudger to disconnect the ribbon from the mother board.
  3. Kindle Fire HD 2013 Battery Replacement: step 3, image 1 of 2 Kindle Fire HD 2013 Battery Replacement: step 3, image 2 of 2
    • Peel battery away.
    • Battery is glued and may cause permanent damage if bent.
aaa
733 Reputation
5 Guides authored
USF Tampa, Team 2-3, Sullivan Fall 2016 Member of USF Tampa, Team 2-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G3
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 48
All Time: 7,955
