Using the plastic opening tool, carefully insert the opening tool on all four corners of the Kindle Fire and lift up until you hear a slight popping noise
Using the plastic opening tool, start from one corner and go around the Kindle Fire using the tool in a down and up motion to continue to pop off the backing.
The Kindle Fire could possibly have tape on the inside, so take caution and look before attempting to remove the back.
After you lift all four corners and you check for tape, it is safe to proceed.
Once all the plastic clips holding the screen to the plastic back of the Kindle Fire are separated, the back should be safe to lift up completely.
Locate the antenna cable connector which is easier to find if you look for the gold tipped black wire that surrounds the battery.
Use the plastic opening tool to remove the plastic piece that connects the wires to the motherboard
Look at the speakers on the left and right side of your device. Unscrew the three 2 mm screws that hold the speakers down with the Phillips #000 screwdriver.
Locate the black and white wires that are connected to the plastic black piece.
Use the tweezers to lift up the wires.
Locate the purple flap in the middle of the motherboard.
Lift up the little black flap to disconnect the purple flap.
Locate the red and black wire that is connected to the plastic black piece.
Locate the five 3 mm screws and unscrew them with the Phillips #00 screwdriver.
Remember to unscrew the 3 mm screw underneath the cooper flap.
In order to remove the black and red wire, you must first remove the motherboard.
Now it is safe to remove the left and right side speakers out.
