Kindle Fire Frame Loosening
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Kindle Fire Frame Loosening, Frame Loosening: step 1, image 1 of 3 Kindle Fire Frame Loosening, Frame Loosening: step 1, image 2 of 3 Kindle Fire Frame Loosening, Frame Loosening: step 1, image 3 of 3
      • Use the flat end of a spudger to peel the ambient light sensor cable off of the frame.
      • You will need to peel up the silver tape in the cable's lower right bend. The silver tape under the lower left bend of the cable does not need to come up with it.
      Ask FixBot
    2. Kindle Fire Frame Loosening: step 2, image 1 of 1
      • Use the flat end of a spudger to peel up the silver tape securing the antenna cable.
      Ask FixBot
    3. Kindle Fire Frame Loosening: step 3, image 1 of 1
      • Remove the five 3.6 mm Phillips #00 screws securing the frame and ambient light sensor.
      Ask FixBot
Phillip Takahashi
88,111 Reputation
87 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 16
All Time: 769
