Up to 20% off select tools
Kindle 3 Keyboard Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
35
All Time:
192
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Tools
Introduction
Go to step 1 ↓
Archived/legacy version of the student-created keyboard guide.
    1. Kindle 3 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Insert a plastic opening tool into the seam between the back and front of the Kindle 3 (as indicated in the photograph).
      • If you have difficulty inserting the plastic opening tool, run the flat edge of the instrument along the seam to find a gap.
      • Using the plastic opening tool, lift the back cover of the device.
      • Remove the back cover.
      Ask FixBot
    2. Kindle 3 Keyboard Replacement: step 2, image 1 of 3 Kindle 3 Keyboard Replacement: step 2, image 2 of 3 Kindle 3 Keyboard Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the 14 silver screws (4mm) that secure the components within the housing.
      Ask FixBot
    3. Kindle 3 Keyboard Replacement: step 3, image 1 of 1
      • Using the screwdriver, remove the 11 gray screws (4mm) that secure the motherboard to the housing.
      Ask FixBot
    4. Kindle 3 Keyboard Replacement: step 4, image 1 of 1
      • Remove the battery, starting from the side that was secured by the screws.
      Ask FixBot
    5. Kindle 3 Keyboard Replacement: step 5, image 1 of 3 Kindle 3 Keyboard Replacement: step 5, image 2 of 3 Kindle 3 Keyboard Replacement: step 5, image 3 of 3
      • Using the plastic opening tool, carefully lift the ribbon cable to disconnect it from the motherboard.
      • Latches secure the three remaining ribbon cables to the motherboard.
      • To disconnect the latched ribbon cable, open the latch and gently slide out the cable.
      • The rightmost photograph shows the ribbon cable with an open latch.
      Ask FixBot
    6. Kindle 3 Keyboard Replacement, Remove the 3G card: step 6, image 1 of 1
      • Insert the plastic opening tool underneath the silver-headed black cable and gently disconnect the cable from the motherboard.
      Ask FixBot
    7. Kindle 3 Keyboard Replacement: step 7, image 1 of 2 Kindle 3 Keyboard Replacement: step 7, image 2 of 2
      • The motherboard is connected to the device by a red-and-black twisted pair cable. Do not detach the cable.
      • There are 3 spacers. Two of them are where the two screws attaching the battery were. The third is to the bottom right of the silver motherboard unit. Take care not to lose these spacers when moving the motherboard.
      • With the cable still attached, flip over the motherboard.
      • The silver motherboard unit with a serial number may fall out. If this occurs, slide the unit back into place.
      Ask FixBot
    8. Kindle 3 Keyboard Replacement: step 8, image 1 of 1
      • Remove the gray and gold plates from the housing.
      Ask FixBot
    9. Kindle 3 Keyboard Replacement: step 9, image 1 of 1
      • Replace the damaged keyboard.
      • When reassembling the Kindle 3, test the power switch to make sure it moves freely.
      • When reassembling the device, do not mix up the gray and silver screw slots.
      Ask FixBot
Author
with
James Gauger
555 Reputation
2 Guides authored
CSU Fullerton, Team 1-5, Bruce Fall 2014 Member of CSU Fullerton, Team 1-5, Bruce Fall 2014
CSUF-BRUCE-F14S1G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 35
All Time: 192
