Kid Galaxy Morphibians Explorer Outer Cover Replacement
  1. Kid Galaxy Morphibians Explorer Outer Cover  Replacement, Remove the Top Cover: step 1, image 1 of 1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: step 2, image 1 of 1
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: step 3, image 1 of 1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: step 4, image 1 of 1
    • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
    • Turn the RC car over to reach the six screws on the bottom.
  5. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: step 5, image 1 of 1
    • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
    • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
  6. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: step 6, image 1 of 1
    • Lift the top Cover off the car.
Eric Studstrup
4 Reputation
2 Guides authored
USF Tampa, Team 1-2, Hickman Fall 2014 Member of USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Members
7 Guides authored
One Comment
As i can see in the last image. There are some wires still connected with the outer cover. Could have shown couple more images how to get them off. Everything else looks great.
Dishant Patel - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 218
