Up to 20% off select tools
Keypad Duplicate Guide
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
34
All Time:
2,705
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to take apart your phone in order to replace the keypad and how to attach the new keypad.
    1. Keypad Duplicate Guide, Keypad: step 1, image 1 of 2 Keypad Duplicate Guide, Keypad: step 1, image 2 of 2
      • Face the back of the phone towards you. Locate the oval-shaped button at the bottom of the back cover.
      • Press this button and remove the back of the phone.
      Ask FixBot
    2. Keypad Duplicate Guide: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    3. Keypad Duplicate Guide: step 3, image 1 of 2 Keypad Duplicate Guide: step 3, image 2 of 2
      • Identify the four screw locations.
      • Use a torx head screwdriver to unscrew the four screws. In order to unscrew a screw, insert the screwdriver into a screw and rotate the screwdriver counterclockwise.
      • Set the screws aside.
      Ask FixBot
    4. Keypad Duplicate Guide: step 4, image 1 of 1
      • Unscrew the antenna by rotating it counterclockwise. Remove it from the phone.
      Ask FixBot
    5. Keypad Duplicate Guide: step 5, image 1 of 1
      • Separate the back of the phone by locating a line separating the front of the phone from the back of the phone. Pull on each of these sides of the phone, front and back, in opposite directions.
      • After the phone is separated, the logic board should be exposed.
      Ask FixBot
    6. Keypad Duplicate Guide: step 6, image 1 of 1
      • Carefully lift the logic board. This will reveal the keypad found beneath the logic board.
      Ask FixBot
    7. Keypad Duplicate Guide: step 7, image 1 of 1
      • Remove the keypad from the phone by pulling it towards you and away from the phone.
      Ask FixBot
    8. Keypad Duplicate Guide: step 8, image 1 of 2 Keypad Duplicate Guide: step 8, image 2 of 2
      • If the keypad was removed properly, your phone should appear as shown.
      • You may now insert your new keypad by orientating the number side of the keypad face down into the phone. You should not be able to clearly view the numbers from the back of the phone.
      Ask FixBot
Author
with
iDeleted
2,101 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 34
All Time: 2,705
