Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly
  1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Poweroff: step 1, image 1 of 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Poweroff: step 1, image 2 of 2
    • Unplug and toggle the small orange switch to the off position
  2. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Keycaps: step 2, image 1 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Keycaps: step 2, image 2 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Keycaps: step 2, image 3 of 3
    • Use a keycap puller to remove the keycaps.
  3. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: step 3, image 1 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: step 3, image 2 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: step 3, image 3 of 3
    • Use a switch puller to remove the switches. If you have the included switch puller from Keychrone, it can be tough removing these switches.
    • Each switch has small tabs on the corners to grab and remove them. (Included switch puller might require extra strength to remove)
  4. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of screws holding chassis together: step 4, image 1 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of screws holding chassis together: step 4, image 2 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of screws holding chassis together: step 4, image 3 of 3
    • Use a # 1 philips drill bit to remove the 4 screws
  5. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removing Aluminum top chassis from base: step 5, image 1 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removing Aluminum top chassis from base: step 5, image 2 of 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removing Aluminum top chassis from base: step 5, image 3 of 3
    • Use a spudger or another wedge tool to pry open the plastic base from the aluminum chassis.
    • There are tabs that hold the two in place, be careful to not use too much power when opening.
    • CAUTION: The battery on plastic bottom is connected to the PCB on the USB and orange toggle side.
  6. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnection Battery: step 6, image 1 of 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnection Battery: step 6, image 2 of 2
    • Use tweezers to disconnect the battery from the PCB.
  7. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of PCB from Aluminum frame: step 7, image 1 of 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of PCB from Aluminum frame: step 7, image 2 of 2
    • Remove the 14 screws with a # 1 Philips screw driver bit
    • To remove the PCB from the aluminum frame, you can push from the 'Top' or use a spudger to wedge it out.
  8. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Dissasemble complete: step 8, image 1 of 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Dissasemble complete: step 8, image 2 of 2
    • The PCB is now removed and able to work on.
    • When you reassemble the keyboard, make sure to put the orange toggles with the two nubs pointing towards the switch side of the aluminum frame.
Mike Villasenor
235 Reputation
1 Guide authored
Past 24 Hours: 8
Past 7 Days: 42
Past 30 Days: 215
All Time: 7,173
