Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable
  1. Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speaker Cover: step 1, image 1 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speaker Cover: step 1, image 2 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speaker Cover: step 1, image 3 of 3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 2, image 1 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 2, image 2 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 2, image 3 of 3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 3, image 1 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 3, image 2 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 3, image 3 of 3
    • Hold the speaker cover in one hand and the speaker ear-padding in the other.
    • Turn the speaker cover counter-clockwise until it stops turning.
    • Pull the speaker cover and the speaker ear padding apart to expose the inner components of the speaker.
    • Make sure to pull the speakers apart gently to avoid disconnecting the speaker cable wires from the speaker.
    • If the speaker cover and ear-padding don't easily come apart, then make sure the speaker cover is fully turned.
    • Repeat this process for both speakers.
  4. Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speakers: step 4, image 1 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speakers: step 4, image 2 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speakers: step 4, image 3 of 3
    • With the internal speaker component exposed, the wires connecting the speakers to the speaker cable can be cut.
    • Reassembly after cutting the speaker cable wires will require soldering. Proceed with caution. See Kensington Hi-Fi Headphones 33137 Speaker Cable Replacement.
    • Cut each of the wires connecting the speaker to the speaker cable.
    • Repeat this process for each speaker.
  5. Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speaker Cable: step 5, image 1 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speaker Cable: step 5, image 2 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable, Speaker Cable: step 5, image 3 of 3
    • After cutting the wires, untie the knot that is in the speaker cable.
    • Repeat this process for each side of the speaker cable.
  6. Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 6, image 1 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 6, image 2 of 3 Disassembling Kensington Hi-Fi Headphones 33137 Speaker Cable: step 6, image 3 of 3
    • Pull the speaker cable through the hole in the speaker cover.
    • Repeat this process for each side of the speaker cable to completely remove the speaker cable from all headphone components.
William Sanders
573 Reputation
5 Guides authored
Clemson, Team 1-3, Benson Spring 2014 Member of Clemson, Team 1-3, Benson Spring 2014
CLEM-BENSON-S14S1G3
3 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 607
