Kenmore Dryer Disassembly
Views: 1K
View statistics:
Past 24 Hours:
9
Past 7 Days:
69
Past 30 Days:
241
All Time:
1,022
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to fully disassemble a brown-top Kenmore dryer for repair, inspection, or lint cleanup. This procedure exposes the timer, switches, control panel, top panel, front panel, drum, belt, idler pulley, motor, blower wheel, and heating-element assembly. It was written for a brown-top Kenmore dryer, but similar Kenmore models may have small differences in panel layout and fasteners.
Tools
      • Unplug the dryer before removing any panels.
      • Let the dryer cool completely before touching the heater, motor, or internal cabinet parts.
      • Wear work gloves when reaching inside the cabinet because the sheet-metal edges can be sharp.
      • Move the dryer so you can reach both the rear panel and the front of the cabinet.
      Ask FixBot
      • Pull the timer knob straight off the timer shaft.
      • Turn the dryer around so the upper rear panel faces you.
      • Remove the screws securing the upper rear panel with a 1/4 inch nut driver.
      • Lift off the upper rear panel to expose the timer.
      Ask FixBot
      • Record the timer wire locations before disconnecting anything.
      • Disconnect the wires from the timer terminals.
      • Use a flathead screwdriver to gently pry off any tight terminals.
      • Remove the two timer screws with a 5/16 inch nut driver.
      • Lift the timer out of the control panel.
      Ask FixBot
      • Record the start-switch wire locations before disconnecting the wires.
      • Disconnect the wires from the start switch.
      • Remove the two start-switch screws with a 5/16 inch nut driver, then lift out the switch.
      • Record the temperature-selector wire locations before disconnecting that switch.
      • Disconnect the wires from the temperature-selector switch.
      • Remove the temperature-selector switch screws with a 5/16 inch nut driver, then lift out the switch.
      Ask FixBot
      • Locate the ground wires connecting the control panel top to the dryer top.
      • Remove the screws securing the ground wires to the control panel.
      • Remove the two control-panel screws with a Phillips screwdriver.
      • Lift the control panel up and pull it forward.
      • Remove the control panel from the dryer.
      Ask FixBot
      • Pull the lint filter out of the top panel.
      • Remove the two screws under the lint-filter cover with a Phillips screwdriver.
      • Pull up on the rear corners of the top panel to release the front clips.
      • Lift the top panel like a lid.
      • Remove the top panel from the dryer.
      Ask FixBot
      • Remove the two front-panel screws with a 5/16 inch nut driver.
      • There is one screw on each side of the dryer.
      • Record the door-switch wire locations before disconnecting the wires.
      • Disconnect the two door-switch wires.
      • Hold the side panels down and lift the front panel upward.
      • Lift the front panel off the lower hooks and remove it.
      Ask FixBot
      • Reach under the drum and release the belt from the motor pulley.
      • Lift the drum and belt out of the cabinet together.
      • Remove the idler pulley from the bottom of the cabinet.
      Ask FixBot
      • Record the motor wire locations before disconnecting the wiring.
      • These notes will help you reconnect the motor correctly during reassembly.
      • Disconnect the motor wiring.
      • Turn the dryer around so you can reach the blower housing.
      • Remove all rear-panel screws with a 1/4 inch nut driver.
      • Move the rear panel out of the way.
      Ask FixBot
      • Remove the four screws securing the blower-housing cover with a 5/16 inch nut driver.
      • Remove the four upper screws securing the rear drum panel with the same driver.
      • Pull the rear drum panel forward to create working room behind the dryer.
      • Work the blower housing out from behind the dryer.
      • The housing is often tight, but removing it gives you better access for cleaning.
      Ask FixBot
      • Clamp large locking pliers onto the motor shaft.
      • Fit a 13/16 inch open-ended wrench over the square section of the blower wheel that sticks through the rear panel.
      • Push the wrench down to break the blower wheel loose from the motor shaft.
      • Turn the dryer back around to the front.
      • Spin the blower wheel off the shaft by hand.
      • Remove the blower wheel from the housing.
      Ask FixBot
      • Grab the end of the front motor retaining clip with pliers.
      • Pry the front retaining clip off the motor bracket.
      • Pry the rear retaining clip off the motor bracket with pliers.
      • Lift the motor out of the bracket and remove it from the dryer.
      Ask FixBot
      • Record the wire locations on the heater and thermostats before disconnecting anything.
      • Disconnect the wires from the heater and thermostats.
      • Locate the upper heater-bracket screw through the fixed hole in the rear panel.
      • Lift the dryer top and look down at the bracket so you can see the hidden screw.
      • Remove the upper heater-bracket screw with a long 1/4 inch nut driver or a long flathead screwdriver.
      • Lift the heating-element assembly up and out of the dryer.
      Ask FixBot
      • Remove the screw securing the heating element with a 5/16 inch nut driver.
      • Pull the heating element out of the housing.
      Ask FixBot
Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 69
Past 30 Days: 241
All Time: 1,022
