Kenmore 110 Series Washing Machine Water Level Sensor Replacement
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: step 1, image 1 of 1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: step 2, image 1 of 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: step 2, image 2 of 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: step 2, image 3 of 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: step 3, image 1 of 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: step 3, image 2 of 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: step 3, image 3 of 3
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
Robert Trout
1,234 Reputation
5 Guides authored
Cal Poly, Team 15-43, Forte Fall 2012 Member of Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Members
11 Guides authored
Past 24 Hours: 10
Past 7 Days: 46
Past 30 Days: 178
All Time: 40,068
