Kayak Handle Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
86
All Time:
469
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Over time, exposure to UV rays, saltwater, and the physical strain of transporting a heavy vessel can cause kayak handles to fray, crack, or snap. A broken handle isn't just an inconvenience; it can lead to dropped boats and haul damage. This guide provides a straightforward method for replacing a standard kayak handle, ensuring your kayak remains easy to transport and safe to maneuver on land.
Tools
    1. Kayak Handle Replacement, Handle: step 1, image 1 of 1
      • Detach the handle and paracord strap from the kayak.
      Ask FixBot
    2. Kayak Handle Replacement: step 2, image 1 of 3 Kayak Handle Replacement: step 2, image 2 of 3 Kayak Handle Replacement: step 2, image 3 of 3
      • Insert the screwdriver into the head of the bolt on the bottom side of the handle.
      • Apply pressure to the bottom of the handle.
      • Remove the top part of the handle by using the screwdriver to pop it out.
      • Caution: Do not let the hardware fall into the hull, as it may slide into unreachable areas of the bow or stern.
      Ask FixBot
    3. Kayak Handle Replacement: step 3, image 1 of 2 Kayak Handle Replacement: step 3, image 2 of 2
      • Pull the paracord out of the handle so they are separate from each other.
      Ask FixBot
    4. Kayak Handle Replacement: step 4, image 1 of 3 Kayak Handle Replacement: step 4, image 2 of 3 Kayak Handle Replacement: step 4, image 3 of 3
      • Cut the end of the paracord using your knife or a pair of scissors.
      • Insert the paracord into the bottom side of the handle through the small hole.
      • Pull it through so each side of the paracord is evenly inserted.
      Ask FixBot
    5. Kayak Handle Replacement: step 5, image 1 of 2 Kayak Handle Replacement: step 5, image 2 of 2
      • Tie a knot with the paracord using both ends of the already inserted paracord.
      • Pull it tight and be sure that the knot is as close to the edge of the paracord as possible.
      • Cut the excess paracord at the end of the knot if there is any.
      Ask FixBot
    6. Kayak Handle Replacement: step 6, image 1 of 3 Kayak Handle Replacement: step 6, image 2 of 3 Kayak Handle Replacement: step 6, image 3 of 3
      • Pull the paracord through the handle so that the knot is now inside the handle.
      • Add the cover of the handle back onto the top. Secure it down tightly.
      Ask FixBot
    7. Kayak Handle Replacement: step 7, image 1 of 3 Kayak Handle Replacement: step 7, image 2 of 3 Kayak Handle Replacement: step 7, image 3 of 3
      • Locate the metal bar on the kayak and place the looped end of the new handle underneath it.
      • Pull the paracord all the way through until the handle stops it.
      • Loop the paracord over the plastic handle.
      • Pull the handle tightly to secure it in place.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 86
All Time: 469
