Community-Contributed Guide
Introduction
Go to step 1 ↓Replacement of the stack assembly on any Kaffelogic Nano or Nucleus Link coffee roaster with a D or P prefix serial number.
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Remove the last 2.5mm Hex screw securing the rear panel.
Pull up on the rear panel to remove it from the roaster.
Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
Use needle-nose pliers to pull the roast chamber earth lead away from the earthing point.
Remove the terminal PCB cover and set it aside. This is held in with four small plastic clips at each corner.
Remove all four connectors on the left side of the terminal PCB.
Remove the mains earthing connector from the tab. Pliers can be used for this as it can be tight.
Remove the 4x 2.5mm Hex screws securing the gantry plate to the aluminium uprights. A long driver bit is recommended for this.
Well done! Your stack assembly is free!
During reassembly, the star washer should be placed between the gantry plate steel and the earthing tab as pictured.
There is a hole in the gantry plate to route the transformer primary wires through. Hold them to the side as you place the new stack.
