Community-Contributed Guide
Introduction
Go to step 1 ↓Replacement of the mainboard (PCB-A) on any Kaffelogic Nano or Nucleus Link coffee roaster with a D or P prefix serial number.
Tools
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Remove the last 2.5mm Hex screw securing the rear panel.
Pull up on the rear panel to remove it from the roaster.
Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
Remove the 2x 2.5mm Hex screws securing the cable carrier to the base.
Pull the PCB away from the base assembly.
Use pliers to disconnect the transformer secondary wires from the back of the PCB
Your mainboard is now removed and ready for rework or replacement. Replace the serial code on the bottom of your roaster with the included QR label.
