Shop the Holiday Gift Guide
Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
57
All Time:
327
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacement of the LCD board on any Kaffelogic Nano or Nucleus Link coffee roaster with a D or P prefix serial number.
Tools
    1. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Removing Front Panel Screws: step 1, image 1 of 2 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Removing Front Panel Screws: step 1, image 2 of 2
      • Unplug the roaster from mains power before proceeding. Do not perform any of these steps on a live/powered unit.
      • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
      • Take care not to damage the buttons while maneuvering the front panel, with all six screws removed it may fall away.
      Ask FixBot
    2. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Lift the closure: step 2, image 1 of 2 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Lift the closure: step 2, image 2 of 2
      • Hold the front panel steady while removing the plastic top/closure.
      Ask FixBot
    3. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Removing the front panel: step 3, image 1 of 1
      • Pull away the front panel carefully.
      Ask FixBot
    4. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Removing the rear panel: step 4, image 1 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Removing the rear panel: step 4, image 2 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Removing the rear panel: step 4, image 3 of 3
      • Remove the last 2.5mm Hex screw securing the rear panel.
      • Pull up on the rear panel to remove it from the roaster.
      Ask FixBot
    5. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Access granted: step 5, image 1 of 2 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Access granted: step 5, image 2 of 2
      • Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
      Ask FixBot
    1. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove ribbon cable: step 6, image 1 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove ribbon cable: step 6, image 2 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove ribbon cable: step 6, image 3 of 3
      • Gently remove the ribbon cable from the PCB.
      Ask FixBot
    2. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove PCB screws: step 7, image 1 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove PCB screws: step 7, image 2 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove PCB screws: step 7, image 3 of 3
      • Unscrew the 4x PH2 PCB screws.
      • These screws are captive to the PCB.
      Ask FixBot
    3. Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove PCB: step 8, image 1 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove PCB: step 8, image 2 of 3 Kaffelogic Nano 7/LINK (D-P Serial) LCD Board Replacement, Remove PCB: step 8, image 3 of 3
      • Carefully remove the display PCB.
      • You may replace the ribbon cable while you have the panels off.
      Ask FixBot
Author
with
Kaffelogic
2,588 Reputation
17 Guides authored
Kaffelogic Staff Member of Kaffelogic Staff
Community
3 Members
204 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 57
All Time: 327
