Introduction
Replacement of the USB daughterboard on any Kaffelogic Nano or Nucleus Link coffee roaster with a C or N prefix serial number.
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Unplug your motor if your roaster is fitted with a connector, otherwise leave the connections in place.
Pull the board away from the chassis carefully, taking care with any wires still attached. We need to get to the back of the board.
Pull away on the daughterboard to remove it from the main PCB.
