Introduction
Replacement of the thermocouple on any Kaffelogic Nano or Nucleus Link coffee roaster with an A, B, C or N prefix serial number.
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
If your thermocouple connector looks like this, you will need to follow this step.
Use the end of a cable tie or very small plastic spudger to open the contact and remove/insert your thermocouple wires. You may need to trim the cable tie end to fit into the slot.
Carefully unwrap the copper wire used to secure the thermocouple.
Unwind the thermocouple wire from the earth lead, cut any cable ties used to secure excess wire.
Pinch the thermocouple and gently remove it from the tube.
Leave 2mm of thermocouple insulation exposed
Massage the tape firmly over the thermocouple wires to secure the position.
