Community-Contributed Guide
Introduction
Go to step 1 ↓Replacement of the motor on any Kaffelogic Nano or Nucleus Link coffee roaster with an A, B, C or N prefix serial number.
Tools
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Remove the 4x PH1 element chamber screws from the plastic bowl. (One screw not pictured)
When reassembling make sure there is no airgap indicated by the red and blue arrow
Lift the element chamber up carefully to expose the element. Set this aside.
Move the element out of the way so you can continue working towards the motor.
Use an 8mm wrench or socket to remove the nut securing the impeller to the motor.
Some roasters have split bowl legs, allowing better access to the motor by removal of the bowl. However, the motor and mount will fit through the hole in the center of the bowl if your roaster does not have split legs.
Remove any motor pins (if present)
Pinch the 4x rubber mounts to pull them through the slots in the plastic motor mount.
Unplug your motor if your roaster is fitted with a connector, otherwise proceed to de-soldering steps below.
Cut the cable tie holding the motor controller in place.
Disconnect the motor controller cable from the 3-prong connector (This will be positioned differently depending on your board version)
Prepare your soldering iron, and de-solder the red and black motor controller power wires.
Attach your new motor controller, and enjoy your new motor after reversing these steps.
Your new motor kit should include a set of anti-vibration pins, place these inside of the rubber mounts.
Steve has also shared a handy technique for fishing your motor connector cable tie through the gantry place.
