KK-82MS-B Battery Replacement
  1. KK-82MS-B Battery Replacement, Open the calculator.: step 1, image 1 of 2 KK-82MS-B Battery Replacement, Open the calculator.: step 1, image 2 of 2
    • Unscrew the back and open the calculator like a book. Open it carefully so you don't tear the battery wires.
  2. KK-82MS-B Battery Replacement, Remove battery wires.: step 2, image 1 of 2 KK-82MS-B Battery Replacement, Remove battery wires.: step 2, image 2 of 2
    • Lift and remove both wires connected to the battery. They are blue.
  3. KK-82MS-B Battery Replacement, Remove and replace the battery.: step 3, image 1 of 2 KK-82MS-B Battery Replacement, Remove and replace the battery.: step 3, image 2 of 2
    • Unfortunately, you cannot remove the battery without some sort of damage. The easiest way to do this is to break the top so the walls are still there to keep the battery in place.
    • This is very dangerous, there is a high chance of puncturing the battery.
    • Insert your new batteries into the same spot as the previous ones.
    • Slide the blue wires back into place.
Kyeler W
2,782 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 12
Past 30 Days: 57
All Time: 475
