Shop the Holiday Gift Guide
Lenovo Tab 4 TB-8504F Rear Camera Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
54
All Time:
1,161
Comments: 6
6 comments on steps.
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the rear camera is resulting in poor-quality images or isn't capturing pictures correctly, it may be time to replace it. This guide will be useful for the replacement of the rear camera on a Lenovo Tab 4 TB8504F.
The rear camera is used to capture photos and videos in incredible quality and detail. A rear camera that needs to be replaced will produce blurry, low-quality, or blacked-out images/videos.
Before using this guide, be sure your camera lens is clean and attempt to take a picture. If the picture is still blurry, low-quality, or blacked out, the camera may not be working properly.
In a few simple steps, the rear camera can easily be replaced so your pictures and videos can be clear and high quality once again. Be sure to have the proper tools that are listed in this guide, follow the steps directly, and take your time.
Before you begin, your device will need to be powered off and disconnected from any cords (like chargers and headphones).
Step 4 requires you to be gentle with the battery. If at any point the battery is damaged, your tablet will cease to turn on.
After Step 5, you will place the new rear camera in and follow the steps in reverse starting from Step 5 to reassemble your device.
Tools
    1. Lenovo Tab 4 TB-8504F Rear Camera Replacement, Battery: step 1, image 1 of 3 Lenovo Tab 4 TB-8504F Rear Camera Replacement, Battery: step 1, image 2 of 3 Lenovo Tab 4 TB-8504F Rear Camera Replacement, Battery: step 1, image 3 of 3
      • Start at the microSD slot. This is the easiest entry point.
      • Use the opening pick gently to slide underneath the back cover of the tablet.
      • Slide the opening pick around the entire edge of the tablet. Don't force it and work slowly to release all clips.
      • Once all clips are loose, lift and remove the back cover.
      Ask FixBot
    2. Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 2, image 1 of 3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 2, image 2 of 3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the 8 Phillips #000 screws holding the plastic shield.
      • Important: One screw is hidden under the blue "S" sticker.
      • Remove any tape holding the plate shield.
      • Use precision tweezers or your fingers to remove the plate.
      Ask FixBot
    3. Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 3, image 1 of 2 Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 3, image 2 of 2
      • Peel back the yellow protective tape over the battery connector.
      • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
      Ask FixBot
    4. Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 4, image 1 of 3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 4, image 2 of 3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: step 4, image 3 of 3
      • Locate the two stretch-release adhesive strips at the bottom of the battery.
      • Gently pull each strip slowly and straight out under the battery.
      • Don't pull upward, only pull horizontally away from the battery
      • The strips are longer than you think, so take your time
      • Once both strips are off, lift the battery from the frame.
      Ask FixBot
    1. Lenovo Tab 4 TB-8504F Rear Camera Replacement, Rear Camera: step 5, image 1 of 2 Lenovo Tab 4 TB-8504F Rear Camera Replacement, Rear Camera: step 5, image 2 of 2
      Buy
      • Use a spudger to lift the rear camera press-fit connector up and free.
      • Use tweezers to lift the rear camera out of the frame.
      Ask FixBot
Author
with
Ivan Chavez
809 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 54
All Time: 1,161
