Jolla C or Intex Aqua Fish Teardown
  1. Jolla C or Intex Aqua Fish Teardown, Phone & Back Cover: step 1, image 1 of 2 Jolla C or Intex Aqua Fish Teardown, Phone & Back Cover: step 1, image 2 of 2
    • Remove the back cover, starting at the bottom right corner with your nail or a prying tool
  2. Jolla C or Intex Aqua Fish Teardown, Battery, Sims & SD: step 2, image 1 of 2 Jolla C or Intex Aqua Fish Teardown, Battery, Sims & SD: step 2, image 2 of 2
    • Remove the battery
    • Remove all sim-cards
    • Remove the microSD-card
  3. Jolla C or Intex Aqua Fish Teardown, Middle Cover: step 3, image 1 of 3 Jolla C or Intex Aqua Fish Teardown, Middle Cover: step 3, image 2 of 3 Jolla C or Intex Aqua Fish Teardown, Middle Cover: step 3, image 3 of 3
    • Remove all 14 cross-head screws
    • Use a prying tool to separate the middle cover from the phone, working from the bottom slowly up to the top
    • Watch out for the power and volume buttons, which probably fall out of the device.
  4. Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: step 4, image 1 of 3 Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: step 4, image 2 of 3 Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: step 4, image 3 of 3
    • Remove all cross-head screws
    • Remove the antenna wire from the circuit board
    • Pry loose the power & volume button part at the side (it is stuck to the phone with sticky tape) and pull it out
    • Pull out the connector for the bottom cuircuit board
    • Pull out the screen connector
    • Pry loose the connector for the proximity sensor etc
    • Now you can remove the top circuit board
    • Remove the main and front camera connectors
  5. Jolla C or Intex Aqua Fish Teardown, Bottom Cuircuit Board: step 5, image 1 of 2 Jolla C or Intex Aqua Fish Teardown, Bottom Cuircuit Board: step 5, image 2 of 2
    • Remove the antenna cable
    • Remove the speaker and vibration motor from the phone
    • Both items are stuck to the phone and the cables are very fragile. I broke one of the connections when removing the speaker for a second time, as seen in the second picture. It is possible to solder it back on
Jos Wagenmakers
131 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 1,304
