Installing Jazz HDV178 Camcorder Motherboard
  1. Installing Jazz HDV178 Camcorder Motherboard, Back Cover: step 1, image 1 of 1
    • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
    • Press down on the grooved plastic with your thumbs.
    • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
  2. Installing Jazz HDV178 Camcorder Motherboard, Battery: step 2, image 1 of 1
    • Once you have the back cover off, the camcorder should look like this.
    • Look on the battery for a model number to assure that you acquire the correct replacement part.
    • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
  3. Installing Jazz HDV178 Camcorder Motherboard: step 3, image 1 of 1
    • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
  4. Installing Jazz HDV178 Camcorder Motherboard, Housing: step 4, image 1 of 1
    • Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
    • This is the bottom of the camcorder near where the wrist strap connects.
  5. Installing Jazz HDV178 Camcorder Motherboard: step 5, image 1 of 1
    • Remove the 4.5 mm screw located near the battery slot.
  6. Installing Jazz HDV178 Camcorder Motherboard: step 6, image 1 of 1
    • Break the glue that attaches the lens cover to the camcorder by sliding the plastic prying tool beneath the circumference of the part.
    • After the glue is broken, remove the lens cover.
  7. Installing Jazz HDV178 Camcorder Motherboard: step 7, image 1 of 1
    • Use a small plastic pry tool to gently pry off the silver strip on the top of the camera.
    • Make sure to run the tool under the outline of the strip as you pry it off so the plastic does not snap.
  8. Installing Jazz HDV178 Camcorder Motherboard: step 8, image 1 of 3 Installing Jazz HDV178 Camcorder Motherboard: step 8, image 2 of 3 Installing Jazz HDV178 Camcorder Motherboard: step 8, image 3 of 3
    • Locate the side of the camcorder beneath the lens and on the opposite side of the wrist strap.
    • Remove the silver strip using the same process as the previous step.
    • Remove the two 4 mm screws that were hidden under the cover.
  9. Installing Jazz HDV178 Camcorder Motherboard: step 9, image 1 of 3 Installing Jazz HDV178 Camcorder Motherboard: step 9, image 2 of 3 Installing Jazz HDV178 Camcorder Motherboard: step 9, image 3 of 3
    • Pry off the rubbery cap, which covers the buttons. Use the same process as the previous two steps.
    • Slide your prying tool underneath the entire cover to ensure that the glue breaks cleanly and the cover does not snap.
  10. Installing Jazz HDV178 Camcorder Motherboard: step 10, image 1 of 1
    • Remove the three combined buttons so they are not misplaced.
  11. Installing Jazz HDV178 Camcorder Motherboard: step 11, image 1 of 2 Installing Jazz HDV178 Camcorder Motherboard: step 11, image 2 of 2
    • Using a firm hold on both sides of the camcorder, gently pull apart the two halves. Pressure should be evenly distributed across the entire device.
    • If the camcorder does not come apart easily, double check that all of the screws are removed. Return to the previous steps for screw removal if you find a screw that is still attached.
  12. Installing Jazz HDV178 Camcorder Motherboard, Operating Buttons: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the rubber button assembly.
    • Blow on the sensors underneath to remove any dust on the sensors.
    • You can also dab a little rubbing alcohol on the sensor pad with a Q-tip and let it dry.
  13. Installing Jazz HDV178 Camcorder Motherboard, Motherboard: step 13, image 1 of 1
    • Remove the four screws holding on the motherboard.
  14. Installing Jazz HDV178 Camcorder Motherboard: step 14, image 1 of 1
    • Remove 4mm screw under the top button to release the motherboard.
  15. Installing Jazz HDV178 Camcorder Motherboard: step 15, image 1 of 1
    • Gently pull of motherboard to separate from the casing.
Sean
207 Reputation
2 Guides authored
Cal Poly, Team 7-34, Regan Winter 2011 Member of Cal Poly, Team 7-34, Regan Winter 2011
CPSU-REGAN-W11S7G34
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,231
