Introduction
If the charge port in your Jambox has been lost or is not functioning properly, then these are the steps necessary for its replacement. This guide will require minimal soldering.
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
Remove the three T6, 7.0 mm screws under each rubber tab.
I used rubber cement to reattach the pads. That will hold them in place and be easily removable in future.
With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
Unscrew indicated T6 9.7 mm screws.
Gently loosen the tabs from their anchor points so the bottom may be removed.
Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
Pry up the bottom panel by lifting from the device.
Pull the bottom up. This may take a bit of force as the bottom is glued to device.
Once removed, the battery will now be visible.
Turn the Jambox so that the button panel is visible.
Remove the indicated screws, T6 9.6 mm.
Remove the colored ribbon that connects the green button circuit board to the blue auxiliary board by using your finger to lift the small black tabs that clamp down the ribbon.
Thesmallblacktabsshouldnotbelifted.Theywillbebrokenbyliftingthem.Insteadyoushouldslidetheminthedirectionoftheribbon-paralleltotheboard.Theybreakeasilyandleaveyourdeviceworthlessifnotinstalledproperly.Nowmyspacekeynolongerworks.
This destroyed my fix. DO NOT TRY TO LIFT THE PLASTIC TABS!!! Despite what the instruction says it is impossible to do and will break with the slightest pressure upwards. I should’ve read the comment before from another user to slide the tabs OUT in the direction of the ribbon. I’ll keep going thru the steps to finish but this might prove worthless now.
IFIXIT needs to edit this!
Remove the indicated T6 7.4 mm screw holding the auxiliary board in place.
Carefully lift the auxiliary board up and off to the side.
The new charge port will need to be soldered to the logic board. For an exact match use Digi-Key part number CP-018HPJCT-ND
Surely there could be a direct LINK to buy this part?
With a multimeter, test all 3 PCB contacts to determine which are positive, negative and ground. Similarly, ascertain each terminal of your "new" charger port and its corresponding PCB contact. Your "new" port can be a brand-new, identical replacement or a salvaged one of approximate size, post thickness and terminal orientation.
Unless an identical part replacement, you may have to bend your ports terminals in order to make proper contact and'or enlarge the panel opening for the AC plug as I did. To avoid repeat part failure, I hot-glued my charger port onto my PCB after reinforcing my port's terminals with thicker wire and generous solder.
21 other people completed this guide.
11 Comments
Good instruction!
Problem is that the C14 got snapped off too! Not sure if it is really needed. Possible to get the complete board?
I lost C14 as well, anyone have a good replacement number for that?
Jason -
FYI the device will charge and power on without this capacitor. Not sure if it is needed for USB or 3.5mm output, but I don't really care about either of those scenarios.
Jason -
Just did this today. Worked like a champ. Put a little superglue gel under the new charge port and a good amount of solder. Great instructions and was an easy repair.
Mine only works on the charger... does this mean I need to replace the charge port or is it something else wrong ??? I need help please
How can I determine if it is the charge port or the battery that needs to be replaced before I purchase parts??!!
Can someone show the clips please in a photo?
kenneth keen - Reply
