JVC Adixxion GC-XA1BU Lens (External) Replacement
  1. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery: step 1, image 1 of 1
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Lens (External) Replacement: step 2, image 1 of 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Lens (External) Replacement: step 3, image 1 of 1
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Lens (External) Replacement: step 4, image 1 of 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: step 4, image 2 of 2
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Lens (External) Replacement: step 5, image 1 of 1
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery Cover: step 6, image 1 of 1
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): step 7, image 1 of 2 JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): step 7, image 2 of 2
    • Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU Lens (External) Replacement: step 8, image 1 of 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: step 8, image 2 of 2
    • Twist the metal ring on the lens to the right and then pull it off.
  9. JVC Adixxion GC-XA1BU Lens (External) Replacement: step 9, image 1 of 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to gently pry the lens off of the camera.
Christina Michelle Johnson
1,047 Reputation
8 Guides authored
USF Tampa, Team 1-2, Tanski Winter 2015 Member of USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Members
8 Guides authored
One Comment
Where can the lens be purchased at?
Isaac Aguilar - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 609
