JIAYU F1 Battery Replacement
    1. JIAYU F1 Battery Replacement, Turn Off the Phone: step 1, image 1 of 1
      • Turn the phone off by holding down the power button located on the top of the phone.
      Ask FixBot
    2. JIAYU F1 Battery Replacement, Remove the Back Case: step 2, image 1 of 3 JIAYU F1 Battery Replacement, Remove the Back Case: step 2, image 2 of 3 JIAYU F1 Battery Replacement, Remove the Back Case: step 2, image 3 of 3
      • Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool.
      • Gently remove the back case completely from the phone.
      Ask FixBot
    3. JIAYU F1 Battery Replacement, Remove the Battery: step 3, image 1 of 3 JIAYU F1 Battery Replacement, Remove the Battery: step 3, image 2 of 3 JIAYU F1 Battery Replacement, Remove the Battery: step 3, image 3 of 3
      • Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward.
      • Remove the battery from the phone.
      • When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
      Ask FixBot
3 other people completed this guide.
Samantha Fruge
260 Reputation
2 Guides authored
USF Tampa, Team 9-4, Leahy Fall 2014 Member of USF Tampa, Team 9-4, Leahy Fall 2014
USFT-LEAHY-F14S9G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 103
All Time: 1,105
