JD Razor 2000 Handle Bar Replacement
  1. JD Razor 2000 Handle Bar Replacement, Pulling Out the String: step 1, image 1 of 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: step 1, image 2 of 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: step 1, image 3 of 3
    • Firmly hold the handle bar in place.
    • Grab with one hand the black removable tip of the handle bar and pull it out.
    • Pull out the end of the tied string through the removable tip.
  2. JD Razor 2000 Handle Bar Replacement, Untying the Knot: step 2, image 1 of 2 JD Razor 2000 Handle Bar Replacement, Untying the Knot: step 2, image 2 of 2
    • Untie the knot at the end of the string.
    • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
  3. JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: step 3, image 1 of 2 JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: step 3, image 2 of 2
    • Press down firmly on the golden fastening button located on the handle bar being replaced.
    • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
    • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
2 other people completed this guide.
Kevin Church
297 Reputation
2 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
16 Guides authored
One Comment
Why is the stretchable string for?
dantotford - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 24
All Time: 2,046
