Shop the Holiday Gift Guide
JBL Pulse LED Lights Disassembly
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
5
All Time:
217
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. JBL Pulse LED Lights Disassembly, Button Board: step 1, image 1 of 1
      • Use a plastic opening tool to pry around the edges of the circular rubber panel.
      Ask FixBot
    2. JBL Pulse LED Lights Disassembly: step 2, image 1 of 1
      • Once the edges are loose, pull off the rubber button panel completely.
      • New adhesive will have to be applied when reassembling.
      Ask FixBot
    3. JBL Pulse LED Lights Disassembly: step 3, image 1 of 1
      • Use your plastic opening tool to pry the button board loose by lifting the edges.
      Ask FixBot
    4. JBL Pulse LED Lights Disassembly: step 4, image 1 of 1
      • Lift the button board, exposing the attached cable.
      Ask FixBot
    5. JBL Pulse LED Lights Disassembly: step 5, image 1 of 1
      • Pull black piece on top of socket away from board to loosen, then detach the cable.
      Ask FixBot
    1. JBL Pulse LED Lights Disassembly, Outer Casing: step 6, image 1 of 3 JBL Pulse LED Lights Disassembly, Outer Casing: step 6, image 2 of 3 JBL Pulse LED Lights Disassembly, Outer Casing: step 6, image 3 of 3
      • Take out the four 9mm black PH0 screws from the top and bottom of the device.
      • Pull off cap by hand.
      • The outer casing can now be removed.
      Ask FixBot
    1. JBL Pulse LED Lights Disassembly, JBL Pulse LED Lights Disassembly: step 7, image 1 of 2 JBL Pulse LED Lights Disassembly, JBL Pulse LED Lights Disassembly: step 7, image 2 of 2
      • Remove the tape around the cables on the top of the device.
      • Remove the cables by lifting up on the black bracket and then pulling the cable out.
      Ask FixBot
Author
with
Maxwell Busenbarrick
1,401 Reputation
7 Guides authored
USF Tampa, Team 18-6, Blackwell Fall 2016 Member of USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 217
