JBL Grip Charging Port Replacement
    1. JBL Grip Charging Port Replacement, Case: step 1, image 1 of 2 JBL Grip Charging Port Replacement, Case: step 1, image 2 of 2
      • Slide the Jimmy along the seam to separate the case.
      • Caution: Do not bend or puncture membrane.
      Ask FixBot
    2. JBL Grip Charging Port Replacement: step 2, image 1 of 2 JBL Grip Charging Port Replacement: step 2, image 2 of 2
      • Unlatch the membrane from the rest of body.
      Ask FixBot
    1. JBL Grip Charging Port Replacement, Charging Port Panel: step 3, image 1 of 2 JBL Grip Charging Port Replacement, Charging Port Panel: step 3, image 2 of 2
      • Remove the eight 6mm screws securing the panel with a Phillips #2 screwdriver.
      Ask FixBot
    2. JBL Grip Charging Port Replacement: step 4, image 1 of 3 JBL Grip Charging Port Replacement: step 4, image 2 of 3 JBL Grip Charging Port Replacement: step 4, image 3 of 3
      • Flip up the black latches securing the two blue cables connected to the panel.
      • Caution: Do not pull the cables by force. Ensure the latches are fully lifted.
      Ask FixBot
    1. JBL Grip Charging Port Replacement, Charging Port: step 5, image 1 of 2 JBL Grip Charging Port Replacement, Charging Port: step 5, image 2 of 2
      • Remove the four 3 mm screws with a Phillips #2 screwdriver.
      Ask FixBot
    2. JBL Grip Charging Port Replacement: step 6, image 1 of 3 JBL Grip Charging Port Replacement: step 6, image 2 of 3 JBL Grip Charging Port Replacement: step 6, image 3 of 3
      • Lift the charging port from its slot.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 81
All Time: 350
