JBL Grip Case Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
71
All Time:
371
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to safely remove the outer case (membrane) of the JBL Grip speaker. Removing the membrane is a necessary first step to access the internal components of the device, including the charging port and internal circuitry.
The outer case is secured by clips and adhesive, so it must be handled carefully to avoid tearing or deforming the material. Use the recommended tools and apply gentle, even pressure when separating the membrane.
Tools
    1. JBL Grip Case Replacement, Case: step 1, image 1 of 2 JBL Grip Case Replacement, Case: step 1, image 2 of 2
      • Slide the Jimmy along the seam to separate the case.
      • Caution: Do not bend or puncture membrane.
      Ask FixBot
    2. JBL Grip Case Replacement: step 2, image 1 of 2 JBL Grip Case Replacement: step 2, image 2 of 2
      • Unlatch the membrane from the rest of body.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 71
All Time: 371
