JBL Go 3 Grille Replacement
  1. JBL Go 3 Grille Replacement, Grille: step 1, image 1 of 3 JBL Go 3 Grille Replacement, Grille: step 1, image 2 of 3 JBL Go 3 Grille Replacement, Grille: step 1, image 3 of 3
    • Using an iFixit Opening Pick or a Jimmy, pry along the seam between the rubber outer layer and the hard shell.
    • Work your way around the edges until the shell loosens and can be fully removed.
  2. JBL Go 3 Grille Replacement: step 2, image 1 of 3 JBL Go 3 Grille Replacement: step 2, image 2 of 3 JBL Go 3 Grille Replacement: step 2, image 3 of 3
    • Once the shell is loosened on all sides, gently lift and remove it completely.
    • Align the new shell with the speaker’s body, making sure all edges are properly positioned.
    • Press firmly around the edges until the shell snaps securely into place.
To reassemble your device, follow these steps in reverse order.
Kasey Oliver
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 185
