JBL Go 2 Driver Replacement
View statistics:
Past 24 Hours:
10
Past 7 Days:
74
Past 30 Days:
224
All Time:
753
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
The internal speaker driver in a JBL Go 2 is the core component that converts electrical signals into audio vibrations. Over time, the driver can wear out or become damaged. This can lead to distorted audio issues. Replacing the internal driver is an effective way to restore the speaker’s performance and deliver clear audio.
Tools
    1. JBL Go 2 Driver Replacement, Driver: step 1, image 1 of 1
      • Make sure the speaker is completely powered off and unplugged from any cording.
      Ask FixBot
    2. JBL Go 2 Driver Replacement: step 2, image 1 of 1
      • Pry the speaker housing carefully, starting from the corner.
      Ask FixBot
    3. JBL Go 2 Driver Replacement: step 3, image 1 of 2 JBL Go 2 Driver Replacement: step 3, image 2 of 2
      • Use a Phillips head screwdriver and unscrew the internal 9mm screws on each corner of the speaker.
      • After all four 9mm screws are detached, separate the speaker housing from the rest of the speaker.
      • When separating the speaker housing, make sure to be careful as internal wires are connected to the speaker housing and the rest of the speaker.
      Ask FixBot
    4. JBL Go 2 Driver Replacement: step 4, image 1 of 2 JBL Go 2 Driver Replacement: step 4, image 2 of 2
      • Disconnect the driver connector.
      Ask FixBot
    5. JBL Go 2 Driver Replacement: step 5, image 1 of 2 JBL Go 2 Driver Replacement: step 5, image 2 of 2
      • Remove the four 9 mm screws that secure the driver.
      Ask FixBot
    6. JBL Go 2 Driver Replacement: step 6, image 1 of 2 JBL Go 2 Driver Replacement: step 6, image 2 of 2
      • Make sure the internal wires are disconnected.
      • Gently pry the driver out of its assembly.
      Ask FixBot
Elisa Llanes
469 Reputation
4 Guides authored
Texas Tech, Team 8-3, Johansen Spring 2026 Member of Texas Tech, Team 8-3, Johansen Spring 2026
TTU-JOHANSEN-S26S8G3
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 74
Past 30 Days: 224
All Time: 753
