JBL Clip 4 Back Housing Replacement
    1. JBL Clip 4 Back Housing Replacement, Front Grill: step 1, image 1 of 1
      • Remove the front grill with a pry tool. The front grill is glued onto the device.
      Ask FixBot
    2. JBL Clip 4 Back Housing Replacement: step 2, image 1 of 1
      • Now you just need to pry it off using your chosen tool and it should come off easily leaving you with the front grill separated from the device. Your device should look like this after removing the front grill.
      Ask FixBot
    1. JBL Clip 4 Back Housing Replacement, Back Housing: step 3, image 1 of 1
      • First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
      Ask FixBot
    2. JBL Clip 4 Back Housing Replacement: step 4, image 1 of 1
      • Now with the unscrewed front and back housing, you should see some cables that connect between the two. Simply unplug these cables and the back housing will come apart from the front.
      Ask FixBot
james tudor
92 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 109
All Time: 321
