JBL Clip 3 Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
9
Past 7 Days:
60
Past 30 Days:
308
All Time:
11,870
Comments: 9
6 comments on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Clip 3 is IPX7 waterproof and offers up to 10 hours of playtime, powered by a 1000mAh rechargeable Li-ion battery. If the battery is not charging or holding adequate charge, the battery may require replacement.
This guide will show you the step by step process of replacing a speaker battery for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts on this device, because they can be fragile.
Parts
Tools
    1. JBL Clip 3 Battery Replacement, Speaker Grill: step 1, image 1 of 2 JBL Clip 3 Battery Replacement, Speaker Grill: step 1, image 2 of 2
      • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
      • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
      Ask FixBot
    1. JBL Clip 3 Battery Replacement, Speaker Housing: step 2, image 1 of 2 JBL Clip 3 Battery Replacement, Speaker Housing: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
      Ask FixBot
    2. JBL Clip 3 Battery Replacement: step 3, image 1 of 1
      • Separate the speaker housing from the rest of the body.
      • This requires minimal force; they are not glued together.
      Ask FixBot
    3. JBL Clip 3 Battery Replacement: step 4, image 1 of 2 JBL Clip 3 Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
      Ask FixBot
    1. JBL Clip 3 Battery Replacement, Carabiner Clip: step 5, image 1 of 2 JBL Clip 3 Battery Replacement, Carabiner Clip: step 5, image 2 of 2
      • Lift the metal carabiner clip from the speaker housing.
      • They are not glued together and should separate easily.
      • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
      Ask FixBot
    1. JBL Clip 3 Battery Replacement, Speaker Battery: step 6, image 1 of 2 JBL Clip 3 Battery Replacement, Speaker Battery: step 6, image 2 of 2
      Buy
      • Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
      • The wires connecting to the battery are not very long, so be careful when removing them.
      Ask FixBot
    2. JBL Clip 3 Battery Replacement: step 7, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the four screws that secure the motherboard.
      Ask FixBot
    3. JBL Clip 3 Battery Replacement: step 8, image 1 of 1
      • Gently lift the motherboard away from the speaker housing.
      • Take care not to damage the soldered connections when lifting the motherboard.
      Ask FixBot
    4. JBL Clip 3 Battery Replacement: step 9, image 1 of 2 JBL Clip 3 Battery Replacement: step 9, image 2 of 2
      • Use an opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
      • Avoid puncturing or bending the battery. It is a Lithium cell, so there is a bit of risk involved when completing this step. Be careful and patient, and there will not be any complications.
      • During reassembly, remember to superglue the new battery back into place.
      Ask FixBot
6 other people completed this guide.
Kyle Montague
265 Reputation
2 Guides authored
3 Guide Comments
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
B.Bender - Reply Share
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee - Reply Share
Thank you - very helpful guide! Was able to replace my battery with no issues.
JB Zorg - Reply Share
Past 24 Hours: 9
Past 7 Days: 60
Past 30 Days: 308
All Time: 11,870
